Getting IK To work?
How do I get IK to work? If I want to move an arm, do I click on the hand And then go To the edit menu, and Select "Enable IK"? Is that supposed to work?
  • crosswindcrosswind Posts: 8,084
    No... Enable IK is activated as default. You just need to select the hand, hit Spacebar to create its IK chain node (Pin Translate / Rotation), then drag the arm to move or dial the rotation properties of the arm to move...
  • inquireinquire Posts: 2,245
    I forgot to mention that I'm using a Macintosh. Is it still just hit the space bar? But I'll check it out.
    Ah... I have no idea about Mac, pls further check that out ~~
