Shape/Morph not shown
Dear Daz community!
I have a problem with this specific item: https://www.daz3d.com/vintage-scuba-gear-for-genesis-8-females that I purchased a few months ago.
For some reason the morph ''Maskup'' does not appear in the list inside Daz3d even tho it gets installed into the correct folder.
I already tried EVERYTHING like: uninstalling the addon multiple times, reinstalled DAZ and even renamed the file but nothing works out for me.
I tried to reach out to the DAZ Support but never got any response sadly. I hope that someone here can help me to solve that problem.
  • crosswindcrosswind Posts: 8,069
    Scroll down to the bottom of the properties of the Mask.... you should be able to find it.
    2560 x 1392 - 481K
  • frank0314frank0314 Posts: 14,312
    What AV are you using? How did you install it? Manual, Connect, or DIM?
    It's not there unfortunatly
    I used the install manager.
    Go to the installed tab, select everything or just that product, right click, then select Re-Import Metadata and see if that works.
  • Are you applying the mask to a G8F character (or autofitting it to another figure)?
    I've had items autofit and not transfer morphs over before.  Not sure if this is going on in your situation.
    Lee
    Have you checked if the file : MaskUp.dsf locates in the folder: your Daz Library\data\HolbeinC\Vintage Scuba\VS Divemask\Morphs\HolbeinC\Base\  ?
