DAZ 4.5 - 3Delight plugin failure
none01ohonenone01ohone Posts: 862
Just installed the new Daz Studio 4.5 on a freshly installed WinXP 32bit sp3. Working offline.
The two 3delight render plugins fail and when I click render, an error box appears and says - no render engine available.
The other render modes work, but with poor results.
Anyone know of a solution to this?
Thanks.
    It seems to happen on XP 32 bit for some users, how much RAM you have could be the problem.
  • none01ohonenone01ohone Posts: 862
    Thanks for the info.
    At the mo, 512MB. Just orded a couple 1gig sticks.
    Only wanted to test the installation before I bugger up my main PC.
    Thanks.
    I am surprised that you can get DS4P to run at all on only 512 MB? That is a tiny amount of RAM by today's standards.
    My system has 8 GB, and it is pushing the limits some times on the 64 bit version.
    Just fitted 2Gig and I still get:
    Unable to render, No Render Engine Available - error message
    Guess its not the memory?
    Yes I have installed it on an older PC of mine, Athlon single core 2Ghz, ATI 9800 All in Wonder, directX9c, but like I said I wanted to do a fresh test installation.
    My main Pc isn't much more powerfull anyway, just a 2core 2Ghz, ATI HD5500. Guess I wont be purchasing any new stuff for Daz Studio 4.5 as its a dead end for me!
  • DoctorJellybeanDoctorJellybean Posts: 8,464
    It could be your video card. After you have started DS, click on Help - Troubleshooting - View Log, and see what it says about your video card. Or you could attach the log.txt and I'll have a look (it doesn't contain any personal data).
    Did you reinstall ds 4.5? You are giving up way too soon, DS should run OK on a 2GB system.
    Have you looked in Help > About Installed Plugins, that will tell you is the plugin loaded, it is called '3Delight Renderer' in the plugins list and is near the top.
    +++++++++++++++ DAZ Studio 4.5.0.114 starting +++++++++++++++++
    Platform bits: 32
    Qt Version: 4.8.1
    Running on Windows XP, Build 2600, Service Pack 3
    CPU String: AuthenticAMD
    Stepping ID = 1
    Model = 8
    Family = 6
    The following features are supported:
    x87 FPU On Chip
    Virtual-8086 Mode Enhancement
    Debugging Extensions
    Page Size Extensions
    Time Stamp Counter
    RDMSR and WRMSR Support
    Physical Address Extensions
    Machine Check Exception
    CMPXCHG8B Instruction
    APIC On Chip
    SYSENTER and SYSEXIT
    Memory Type Range Registers
    PTE Global Bit
    Machine Check Architecture
    Conditional Move/Compare Instruction
    Page Attribute Table
    Page Size Extension
    MMX Technology
    FXSAVE/FXRSTOR
    SSE Extensions
    CPU Brand String: AMD Athlon(tm) XP 2000+
    Cache Line Size = 64
    L2 Associativity = 8
    Cache Size = 256
    Total Physical Memory: 2047 Mb (2146942976)
    Available Physical Memory: 1651 Mb (1731928064)
    Total Virtual Memory: 2047 Mb (2147352576)
    Available Virtual Memory: 1906 Mb (1998880768)
    Current Memory Usage: 19%
    Sat 15. Sep 09:20:17 2012
    Temp folder: C:/Documents and Settings/mini/Application Data/DAZ 3D/Studio4/temp
    Total temp disk size: 131069 Mb, Available: 14156 Mb
    Locale: en_GB
    No translator found.
    Reading style definition C:/Program Files/DAZ 3D/DAZStudio4/resources/style/Main Street.style
    Creating managers
    Reading help index
    Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/DAZ Studio/DAZStudioHelp.dsx
    Reading help file C:/Program Files/DAZ 3D/DAZStudio4/docs/inlinehelp.dsx
    Scanning import folders
    Scanning content folders
    Using GLEW 1.7.0
    Supported OpenGL extensions:
    GL_AMD_performance_monitor
    GL_ARB_depth_texture
    GL_ARB_draw_buffers
    GL_ARB_fragment_program
    GL_ARB_fragment_program_shadow
    GL_ARB_fragment_shader
    GL_ARB_framebuffer_object
    GL_ARB_half_float_pixel
    GL_ARB_half_float_vertex
    GL_ARB_map_buffer_range
    GL_ARB_multisample
    GL_ARB_multitexture
    GL_ARB_occlusion_query
    GL_ARB_pixel_buffer_object
    GL_ARB_point_parameters
    GL_ARB_point_sprite
    GL_ARB_shader_objects
    GL_ARB_shading_language_100
    GL_ARB_shadow
    GL_ARB_shadow_ambient
    GL_ARB_texture_border_clamp
    GL_ARB_texture_compression
    GL_ARB_texture_cube_map
    GL_ARB_texture_env_add
    GL_ARB_texture_env_combine
    GL_ARB_texture_env_crossbar
    GL_ARB_texture_env_dot3
    GL_ARB_texture_float
    GL_ARB_texture_mirrored_repeat
    GL_ARB_texture_non_power_of_two
    GL_ARB_texture_rectangle
    GL_ARB_transpose_matrix
    GL_ARB_vertex_array_object
    GL_ARB_vertex_buffer_object
    GL_ARB_vertex_program
    GL_ARB_vertex_shader
    GL_ARB_window_pos
    GL_ATI_draw_buffers
    GL_ATI_envmap_bumpmap
    GL_ATI_fragment_shader
    GL_ATI_meminfo
    GL_ATI_separate_stencil
    GL_ATI_texture_env_combine3
    GL_ATI_texture_float
    GL_EXT_abgr
    GL_EXT_bgra
    GL_EXT_blend_color
    GL_EXT_blend_equation_separate
    GL_EXT_blend_func_separate
    GL_EXT_blend_minmax
    GL_EXT_blend_subtract
    GL_EXT_compiled_vertex_array
    GL_EXT_copy_texture
    GL_EXT_draw_range_elements
    GL_EXT_fog_coord
    GL_EXT_framebuffer_blit
    GL_EXT_framebuffer_multisample
    GL_EXT_framebuffer_object
    GL_EXT_gpu_program_parameters
    GL_EXT_multi_draw_arrays
    GL_EXT_packed_depth_stencil
    GL_EXT_packed_pixels
    GL_EXT_point_parameters
    GL_EXT_rescale_normal
    GL_EXT_secondary_color
    GL_EXT_separate_specular_color
    GL_EXT_shadow_funcs
    GL_EXT_stencil_wrap
    GL_EXT_subtexture
    GL_EXT_texgen_reflection : NOT INITIALIZED
    GL_EXT_texture3D
    GL_EXT_texture_compression_s3tc
    GL_EXT_texture_cube_map
    GL_EXT_texture_edge_clamp
    GL_EXT_texture_env_add
    GL_EXT_texture_env_combine
    GL_EXT_texture_env_dot3
    GL_EXT_texture_filter_anisotropic
    GL_EXT_texture_lod_bias
    GL_EXT_texture_mirror_clamp
    GL_EXT_texture_object
    GL_EXT_texture_rectangle
    GL_EXT_texture_sRGB
    GL_EXT_texture_swizzle
    GL_EXT_vertex_array
    GL_KTX_buffer_region
    GL_NV_blend_square
    GL_NV_texgen_reflection
    GL_SGIS_generate_mipmap
    GL_SGIS_texture_edge_clamp
    GL_SGIS_texture_lod
    GL_WIN_swap_hint
    WGL_EXT_swap_control : NOT INITIALIZED
    WGL_ARB_extensions_string
    WGL_ARB_pixel_format
    WGL_ATI_pixel_format_float
    WGL_ARB_pixel_format_float
    WGL_ARB_multisample
    WGL_ARB_pbuffer
    WGL_ARB_render_texture
    WGL_ARB_make_current_read
    WGL_EXT_extensions_string
    WGL_ARB_buffer_region
    WGL_EXT_framebuffer_sRGB
    WGL_ATI_render_texture_rectangle
    WGL_EXT_pixel_format_packed_float
    WGL_I3D_genlock
    WGL_NV_swap_group
    WGL_ARB_create_context
    WGL_AMDX_gpu_association
    : NOT INITIALIZED
    OpenGL features for current hardware:
    OpenGL provider: ATI Technologies Inc.
    OpenGL renderer: RADEON 9800 SERIES
    OpenGL version: 2.1.8545
    Maximum number of lights: 8
    Number of auxiliary buffers: 0
    Number of texture units: 8
    Depth buffer bit resolution: 24
    Maximum OpenGL texture size: 2048 x 2048
    Current OpenGL Texture Quality Setting: Good Performance
    RGBA color bitplane resolutions: 8 8 8 8
    GLSL version: 1.20
    Shadow mapping supported
    VBO supported
    *** Scene Cleared ***
    Loading plug-ins:
    aniMate2.dll
    dazscriptide.dll
    dz3dconnexion.dll
    dz3dmouse.dll
    dzalignace.dll
    dzassetiofilters.dll
    dzautofit.dll
    dzautoriggerbasic.dll
    dzautoshaderbakeractions.dll
    dzbrycebridge.dll
    dzbvh.dll
    dzcolladax.dll
    dzcomponents.dll
    dzcontentdbeditor.dll
    dzcontentlibrarypane.dll
    dzcr2exporter.dll
    dzcustomizedlg.dll
    dzdelightrenderer.dll
    C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzdelightrenderer.dll failed to load. Cannot load library C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzdelightrenderer.dll:
    dzdformeditor.dll
    dzeasyloader.dll
    dzexpexporter.dll
    dzfbxexporter.dll
    dzfbximporter.dll
    dzfiguresetup.dll
    dzhexagonbridge.dll
    dzimageio.dll
    dzjointeditor.dll
    dzlayerededitor.dll
    dzlayerfilter.dll
    dzmanualshaderbaker.dll
    dzmaptransfer.dll
    dzmorphfollower.dll
    dzmorphloader.dll
    dzmorphloaderpro.dll
    dzobjexporter.dll
    dzoptitexclothbasic.dll
    dzpolygongroupeditortool.dll
    dzprimitives.dll
    dzpropertyeditor.dll
    dzpuppeteer.dll
    dzpz3importer.dll
    dzrenderedit.dll
    dzrenderlibrary.dll
    dzrslshadercompiler.dll
    dzsavefilters.dll
    dzscriptedrenderer.dll
    C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzscriptedrenderer.dll failed to load. Cannot load library C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzscriptedrenderer.dll:
    dzscriptedsteps.dll
    dzshaderbaker.dll
    dzshaderbuilder.dll
    dzshadereditor.dll
    dzshadermixerbase.dll
    dzshadermixergui.dll
    dzsmartcontentpane.dll
    dzspotrendertool.dll
    dztextureatlas.dll
    dztransferutility.dll
    dzu3dexporter.dll
    dzweightmapbrush.dll
    dzwinvideo.dll
    sdk_sceneinfopane.dll
    dzmimicbasic.dll
    dzpowerpose.dll
    Total class factories: 1188
    WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
    3D mouse support library could not be loaded.
    Creating interface
    Successfully created OpenGL viewport for Viewport1.
    Successfully created OpenGL viewport for Viewport2.
    Successfully created OpenGL viewport for Viewport3.
    Successfully created OpenGL viewport for Viewport4.
    Executing startup script...
    Started in: C:/Program Files/DAZ 3D/DAZStudio4
    DAZ Studio Started
    Creating Pixel Buffer
    Pixel buffer - Width: 1024 Height: 1024
    Compiling OpenGL Shader...
    Fragment Shader:
    Fragment shader was successfully compiled to run on hardware.Fragment Shader compiled successfully.
    Linking Shader:
    Fragment shader(s) linked, no vertex shader(s) defined.
    Shader Program successfully linked.
  • ReDaveReDave Posts: 815
    You have this: dzdelightrenderer.dll not loading for whatever reason (scripted rendere dll too, but it should follow from the first , I think?). I'd try redownloading after clearing cache and reinstalling.
    edited September 2012
    When a DLL fails to load, in the About Installed Plugins usually says :
    Reason: Library could not be loaded. File is not a valid DAZ Studio plug-in, or was made for a different version of DAZ Studio.
    Did you 'buy' DS4.5 through the store, or did you go to the download from the Home page?
    The main installer contains all of the correct plugins for the version that it is installing. It sounds as if you have the wrong version of the render plugins in your Plugins folder. Did you ever have DS4 installed before, and if so, did you allow the new installer to uninstall the old version?
    I cannot figure out why this is happening, but there is something wrong with the two plugin DLLs. I can't see how it would be a corrupted download that just corrupted the two 3Delight plugins?
    Can you look in Program Files > DAZ 3D > DAZStudio4 > Plugins, and see if the date for the dzdelightrenderer.dll is the same as the rest of the plugins in that folder?
    XPost Dave - sorry - took me forever to type that
    Post edited by JimmyC_2009 on
    I've just re-download 4.5. I'll dig out an old drive and re-inst XP, update to sp3, before I just install 4.5 fresh.
    I've previously installed older versions and during the installation of 4.5 it asks to uninstall the older version, which I did.
    Ah well, all fun and games in PC land. wont BRB, think I'll rest my noddle for a bit.
    Thanks.
