In my experience, removing or reordering layers doesn't really work. What you can do is create a new L.I.E. based on the current one, excluding and reordering as you please, and replace the texture channel in the shader with the new layered image.
I concur...it often doesn't work right to just reorder an existing one.
If it's to remove some of the multiple layers applied by a user, I wouldn't know. But you can still make a LIE remover. If a face has one or more LIE applied. Simply remove all LIE manually. And then File > Save As > Material Preset. Uncheck All. And save only what had LIE layers applied.
Elements of the answer through this script I guess ?
this is what i really want to know too for scripting. I need a script that removes a layer based on name.
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/images/create_layered_image_backdrop/start
