DS 4.5 - Broken Beard? - Unreadable morph files?
xjadexxxxjadexxx Posts: 43
I have a great product, the Short Beard for Genesis, which stopped follow face morphs with 4.5. I wondered if it might be that the morph files had been reset, and went to check on them. I discovered that the new files, when opened with Notepad, have jibberish inside. The old morph files were readable and modifiable with Notepad.
Does anyone know how to read and modify the morph files for 4.5? Specifically the path I went down was Data>Daz 3d>Genesis>Base>Morphs>Daz 3d>Base to get to the files I need to verify. Under DS 4.0+ the morph files for this beard had to have some "autofollow" toggles set to "true".
As always, anyone out there with a solution will be paraded through the streets, showered in rose petals.
Thank you!
  • Richard HaseltineRichard Haseltine Posts: 101,901
    The files are just compressed. You can extract them with an archive utility (I've used 7Zip), or using the Batch Convert pane in DS itself.
