Autopsy-New and Shinny : ) Or with Alien Innards [Commercial]
![AntMan](https://delorean.daz3d.com/forums/uploads/userpics/140/nEBCD4CAA3ED6.gif)
Not sure if this was meant to go live today but.... So check it out and I hope you like it. And if you want to belive... ya the truth is everywhere and it's nasty.
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/76/20dd2c7900181526b8b2e30e991a1b.jpg)
2100 x 1056 - 2M
Post edited by AntMan on
Wow! That is impressive!
All it needs is either Doc Robbins or Ducky Mallard! Very nice indeed.
Seriously you outdid yerself on this one. I never thought i'd use the term beautiful in conjunction with a morgue but damn sir, this thing is gorgeous work. I don't even have an immeadiate use for it but I had to grab it anyway just on its merits. The amount of detail you put in there blew my mind.
Amusingly, I've just been working on a project with AntFarm's Sci-Fi Med Bed ... for an autopsy.
Shiney, brand spanking new, and now purchased. As Vhardamis said, " grabbed it just on its merits" Gorgeous work. The promo of the guy sitting up under the covers was a nice touch.
Thanks everyone! The add on set for this should be coming soon. Sneek Peek
Oh, that is cool.
I plan on getting it; have a use for it, but no credit atm.
This just happened to sneak into my cart last night whilst I was checking out. Amazing set!
Hmm... well, someone will eventually have to die in my story...![laugh laugh](http://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/teeth_smile.png)
I want to belive, the expansion will be here soon.
Sounds like a fairy tale; always lots of bad stuff in those. :) Not like in the real world where nothing bad ever happens.
Keep watching the skies! especially on the night of the third… : )
The truth is out! And it is messy!
Hi Antman
I bought the Alien Autopsy this morning, and I've just tried it out but seem to be having a problem. Everytime I load the figure I get the warning 'data/daz 3d/genesis/base/uv sets/daz 3d/genepool/michael 5.dsf' and the texture looks odd like it's not stting correctly (white patches and darker bits like it's ove lapping). Am I doing something wrong, I'm not sure if I need to get michael 5 or not. Ta :)
Ok, it does sound like a uv map issue when you select People/ Genesis/ Characters/AntFarm in the contents or My Daz Library you should see two thumbnails.
One is “The Gray Autopsy” and one is “The Gray" if you double click or load one of them the figure should appear all ready to go. If you did try that and there is an issue, we have a problem.
Let me know
AntMan
Is it for Genesis 1?
Yes, I figured everyone has it and since most of the facial expression and other added muscle morphs weren't needed why not go with it. Remember It is an HD morph so it does have nice detail.
Is the gray alien for gen 3?
He mabybe she???? It, works with the Genesis figure which has no number. So it should be in your Library already and like I said somewhere above if you just click on the character thumbnail he should beam right into your scene. ; )
Hey Antman
Thanks for getting back to me. I was in the land of nod when you posted then rushed off straight to work so havn't had the chance to try your suggestion. When I get home tonight I'll give it a go and report back.
Cheers :)
It's splendid to have a Grey-type alien with Iray skin!
Hi Antman
I've just tried 'The Grey' again and I'm still getting the same problem. The error message I'm getting is 'data/daz 3d/genesis/base/uv sets/daz 3d/genepool/michael 5.dsf' and the textures aren't sitting on the figure correctly. I loaded the figure straight from the smart content tab under products. Is there anything else you need?
Thanks, great figure by the way :)
Looks awesome :)
Keeping it neil, I just got some help from Richard Haseltine. Genesis "one" does not come with the Michael 5 base it was an add on. It was a part of Genesis 2 however. Do you have that figure? This should have been in the "Requires..." but somehow we all missed it. You can of course return the package but I would hate for that to be the end of the story.
Thanks Richard!
This may have already been answered, but regarding the Autopsy set's 3Delight materials, are there materials for all props or just for the room itself? Cause I can only find one file that only seems to work on the room :D
For the textures, No is the short answer. The room was buit using PBR textures and had to have a second texture to work with Studio's 3delight. But the props worked already with 3delight, it’s just not going to give you the look the Iray render dose. The main issue with 3Delight and Iray is they both create chrome in very different ways. But you can convert any texture to 3Delight with this tool included in Daz Studio (see attachment) It only changes it to 3Delight it leaves maps in place. So chrome Props and such will render just not like in Iray. Still for chrome it’s more about the reflection properties. I copied over the setting in the steel morgue draws and made a shader so you can use it to texture the table and sink to match. This is not DAZ sanctioned so use it if you want to but…
It requires the Autopsy set be installed to work by the way.
Wow there really are no easy answers.
https://www.dropbox.com/s/8xp0o2i6wzp91g2/Chrome.zip?dl=0
Thanks a lot for the information and the preset! Sorry for the extra work I caused, but I wanted to ask before I spend several hours obsessively testing out my library of metal shaders only to find that I missed a preset somewhere ^^ I really love the set btw., been waiting for something like this for a while.
Well, I did end up playing around with the surfaces in 3Delight for a bit, still not quite there, but I am starting to like the results. Thanks again, for the product and the help with it!
Hi Richard
I don't have Michael 5 but will get him later in the month so I can get it working. I have plans for this guy :)
Thanks for your help, I really appreciate it.
Neil
Barubary, Looking good! Morgues make even pretty people look creepy. Yikes!
