DAZ3D upgrade -ish
Small thing I would LOVE to see added to DAZ3D
the ability to create a 'spawn point'...that looks like a small target on the ground
with a single direction arrow pointing out from the center of the icon.
WHAT DOES IT DO ??? you ask
you create one (and only one) on the ground, then you can QUICKLY move it
were you like in the scene, then any models brought in after it is set..pop in there, instead of the usual location.
The model also pops in facing the direction of that arrow on it.
great when placing stuff in a complicated multi-level set new stuff pops in aprox where you need it
    you want that added to Daz 3D.   In the Daz 3D Store?  or in the Daz 3D Forums?   and how would it enhance our browsing experience.
  • Richard HaseltineRichard Haseltine Posts: 100,833
    If this is Daz Studio hold down the alt(Win)/opt(Mac) key and drag an item from the library to the viewport - you will get a target icon showing where the item will load (or rather, the point relative to which the item will load - if it's offset from the origin then it will be equally offset from the target).
  • father1776father1776 Posts: 982
    GOOD TO KNOW !
    ALT DRAG
    Chohole, was talking about daz3 studio main program...BUT the ALT DRAG to get your new item in the correct spot
    is just about as good...thxs
    Daz 3d is the Company Daz studio is the program, normally referred to as DS.
