Help needed with Clothing Cleavage Modifier
TJohn
OK, I've read the read me file that came with this at least a dozen times and still have no idea how to find the morph controls for this, let alone use them. I have DS4 Pro and need some help with this. Does anyone have a link to a good tut or would be able to provide me with the info to get started?
Thanks I would sure appreciate it.
John
You find them in the Shaping Tab under Torso - Universal - Clothing and under Hip - Universal - Clothing.
I'm using the genesis figure and the genesis supersuit. no category for clothing under torso or hip. Maybe it doesn't work with the supersuit? Oh well. Thank you for your quick response.
It's supposed to work on Genesis. You dial it in on Genesis and the suit follows.
Sorry Puntomaus, it's just not working for me. :long:
It looks like this. I have Genesis selected and this should be in the Shaping tab.
Are you using the Shaping pane or the Parameters pane? In the latter theya re under Actor>Upper Body>Torso>Universal>Clothing and Actor>Lower Body>Hip>Universal>Clothing. Note that you do need to be using a new Genesis loaded after installing the morphs, or to apply the Genesis from the library to a previously saved Genesis and then undo to reset pose and materials, to get the morphs.
Thanks. I’m going to try uninstalling and reinstalling the modifier. I’m not getting the “clothing” selection at all yet. If that still hasn’t helped, I’m going to start with a new genesis figure and put a simple shirt and pants on it and see if the “clothing” selection shows up. Then I’ll try redownloading the original file. Then I’ll give up if nothing works, and go on to something more constructive. :-)
A special thanks to you for spending so much time and effort to help out a D/S noob. BTW I’ve been using a lot of 3D programs through the years (20+ years), and the Genesis figures and morphs have added some amazing tools to my 3D arsenal. Now if I can just learn to use them. :)
Cross posted with you, RH. I'm trying to use them on a pre-morphed figure I saved, not a new one. What you're saying helps a lot, I'll start out with a new figure. Thanks.
Load and select your pre-morphed figure. Now find the base Genesis in the content library and double-click it. You should be asked what you want to do - choose to apply it to the current figure, not to load a new one. Now hit Undo which will restore the lost posing and materials but will leave the new morphs loaded and ready for use. You could also save a Character preset (a DSF format preset, not one of the "deprecated" script-based presets) which would do the same thing without needing the undo step.
So I've done those things, I can see "Clothing" and the sliders -- but when I move the sliders, nothing changes, either on the Genesis figure or on the clothing. Shouldn't I be seeing something change? Should the change appear on the Genesis figure? Or just the clothing?
Thanks,
MrWizard1024
The Genesis figure shouldn't change (or rather, shouldn't change visibly) but the clothing should if it's fitted to the Genesis, and assuming you have one of the female morphs dialled in perhaps (I'm not sure if that matters).
