ambient occlusion
laverdet_943f1f7da1
hello guys!!
usually in 3d software, you can have global illumination, for overall diffuse lighting, and ambient occlusion, for strong "frontier" shadow... Is it impossible in C8???
sorry, I don't know how to edit!! I mean, of course, Global ill and AO together!
Do you have Carrara Standard or Pro?
If you have Carrara Pro, then in the Render room under the Output tab, there is a sub-category called Multi-Pass near the bottom. Click the Add button and a new window will open with all the different passes you can select. There is an AO pass. You can add as many as you like.
Hope it helps!
