How do you group an object?
Odaa
I've seen references to having it done, but I haven't been able to find a how to reference in the documentation. Maybe I'm looking in the wrong place.
Select all the components you want to group and then in the little mini menu for your selection, there will be a 'G' button.
Click that to group your objects... then click the 'A' button to go to the attributes and give the group a unique name so you can easily identify it later.
You can select an object by clicking directly on it, or by holding down the left mouse button (LMB) and drag the mouse to creat a bounding box around the object.
If you have several objects, you can chose an individual one by holding down the Ctrl key and left click on the objects. A window will pop up and if you've given each object a unique name, or remember what object number Bryce gave the object, you can click on the name and the object will be selected. Select as many objects as you need, then follow The Savage's instructions.
Thank you guys!
