ArchiTools Won't load [solved]
![Cotru](https://secure.gravatar.com/avatar/dccec453c2706efe188ab81855267306?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fdccec453c2706efe188ab81855267306_100.png)
I have installed the ArchiTools 64 bit plug-in into Carrara 64 bit but when I select the building icon I get an error message which states that the version I have is a network rendering version and it says install the proper version. I also tried the 32 bit version in Carrara 32 bit but get the same message. Does anyone know why this is happening.
I am using 64 bit Windows 7 system.
Problem solved with newer version update. This can be removed.
Post edited by fixmypcmike on
