DzLine3 object
HowieFarkes
OK this is driving me a bit nuts at the moment (and probably because I'm missing something very fundamental). I can't use any methods on a DzLine3 object, I just get the "undefined is not a function errors...
(function(){ var oLine = new DzLine3(); oLine.origin = new DzVec3( 0,0,0 ); oLine.end = new DzVec3( 1,1,1 ); var nLength = oLine.length(); print(nLength); })();
always results in the follwoing output
Executing Script...Script Error: Line 7TypeError: Result of expression 'oLine.length' [undefined] is not a function.Stack Trace: ()@:7Error executing script on line: 7Script executed in 0 secs 2 msecs.
What am I missing?
Of course - what I really want to do is find the distance between 2 vectors - so if there's a better way of finding that out than creating a line between the 2 and getting its length, then I'm all ears.
Hi Howie,
I think something like
Vec1.subtract(Vec2).length()
Should do the trick
Thank you, that worked a treat!
The exposed members of DzLine3 appear to be:
So no length() although it iis listed in the API refrence (but not in the DS3 scripting docs, which look more like the actual list of available members). Please bug report this.
