If the problem is gravity,. you can switch off the default scene gravity, and replace it with a Direction force, (pointing down (default))
The direction force is more controllable , since it can be key-framed, so, you can switch it on when you need it.
HI Kodiak3D :)
not really,.. but you can fake it,
Hope it helps :)
OK, thanks 3Dage, I think that should solve the problem. Much appreciated.
