Upgraded to DS4.5, metadata settings gone
SickleYieldSickleYield Posts: 7,639
I've just upgraded to DS 4.5. When I use Transfer Utility, the Content Type is there but is blank. When I right-click on items in the content library, the words "categorize" and "databases" are there, but they have no options either.
How do I fix this? For that matter, how did I cause it?
    There is a dropdown on the Content Library tab that allows you to reimport Metadata
  • Richard HaseltineRichard Haseltine Posts: 101,002
    Have you check that the CMS is running? In Task manager, look at the Services tab if you are using Windows 7 or Vista.
  • SickleYieldSickleYield Posts: 7,639
    It says it is there and the status is "Running." This is Windows 7.
  • cridgitcridgit Posts: 1,757
    edited May 2022
    Redacted
    Post edited by cridgit on
    Is there anything showing in Content Library > Categories? If not, the CMS either isn't running or is being blocked from communicating with DS4.
    edited October 2012
    Sorry, I wasn't getting post notifications and now it's dumping 50 in my inbox! Eep.
    There is nothing in Content Library - Categories. Maybe I just need to reinstall.
    And cridgit: As far as I know there's only one transfer utility. It has nothing to do with migrating databases, it's just a symptom of the larger problem (in that I no longer have the option of adding metadata to products).
    And I mean they literally have no options. Here's a couple of pics. On Database nothing will appear to the right of that arrow regardless of how I click or hover.
    599 x 600 - 167K
    600 x 531 - 127K
    Post edited by SickleYield on
    edited May 2022
    Redacted
