SOLVED: Duplicate ID's and morphed Genesis at start up
winberrywinberry Posts: 34
Ever since I updated to 4.5, most everything I load, stops in the middle of loading to inform me of "duplicate IDs". Not a big problem, but does mean I have to stay at the desk to click through scenes as they load. Is there anyway to eliminate this (reload 4.5 -- and if so, will I need to reload all content - yikes!)
which leads me to this: all my PEOPLE in Smart Content, now load morphed to a shape, all the same shape, but never the base shape. Is there a fix for this (reset?) Not sure what I did, but I did something..
Thanks for your help..
Post edited by winberry on
  • SzarkSzark Posts: 10,634
    Two ways to fix “duplicate IDs"
    1: update your Genesis content http://www.daz3d.com/forums/discussion/3885/
    2: Grap Richard Fix “duplicate ID" script http://www.daz3d.com/forums/discussion/293/ 4th post down
    As for the other part of your issues with loading a morphed Genesis. Look like you saved over the Default Genesis figure. You wll need to Zero all the Morphs, reverting Genesis to the base and save that as Genesis.duf in the same folder as it was installed to.
  • BejaymacBejaymac Posts: 1,886
    Sounds like you either have a badly done freebie morph (no prizes for guessing which one I'm thinking of), or you've accidentally modified one or more of the regular morphs which is causing it (them) to load in dialed.
  • winberrywinberry Posts: 34
    thanks for the input...my guess is that while trying to learn morphs via Hexagon, I have ove written the original...and thanks too for the ID fix
    well I won't guess then...gees no prizes. :)
