Supercell Tutorial
Hansmar asked if I would show him how I created the supercell for an image I entered into the current Challenge.
The first image shows the wire frame set up from different angles. All thats involved in the storm structure are 3 spheresand 2 Tori.
The two spheres that form the base of the storm perform a boolean operation.
1000 x 1630 - 618K
  • orbitalorbital Posts: 120
    edited June 2016
    Next I set the FOV on the camera to 60%. Most storm chasers will have a wide angled lense when taking photos because the storms are so massive.
    I use Bryce 5, I know a lot will be on 7, so I 'm not sure the exact location of the material I used for the clouds, but it is in there somewhere. There will be a few texture issues because of the way volumetrics interact caused by objects touching, but this can be rectified in post with the clone tool.
    1000 x 1469 - 410K
    698 x 491 - 123K
    Post edited by orbital on
    edited June 2016
    Here is the recipe for the sky. You can change it to what ever you like, but I prefer a low sun positioned to the side as it helps light the clouds have good definition.
    723 x 1562 - 278K
    Another good tip for lighting is explained in this tutorial I did a while back
    https://www.renderosity.com/mod/tutorial/?tutorial_id=2281
    You may need to reduce the brightness of the spotlight as it can sometimes lead to over exposure of the cloud material.
  • drachenlordsdrachenlords Posts: 821
    Thank Orbital for this tutorial. That I needed before my Tornado attempt. * Lol *
  • HansmarHansmar Posts: 2,895
    Many thanks, Orbital. I'll give it a try, but after the contest.
  • mermaid010mermaid010 Posts: 5,388
    Thanks Orbital for the tutorial smiley
  • HoroHoro Posts: 10,537
    edited June 2016
    Thank you orbital. Luckily, I still have Bryce 5 installed. I think due to the volume bug in Bryce 7, it would not work.
    Post edited by Horo on
  • Fencepost52Fencepost52 Posts: 509
    Thanks for sharing, orbital!  I don't have Bryce 5, but will experiment with 7 and see if there are any workarounds that I can come with.
