Opacity & opacity maps
oocreepyoocreepy Posts: 0
Hello there,
So, I'm giving my first steps on DAZ, trying quite hard to learn something, but I came across a problem that I simply cannot solve.
It's very simple, which makes it even more frustrating :-|. Keep in mind that I'm a layman though.
It's about opacity maps, I cannot use them properly and apparently I can't use the opacity strength slider properly too.
Let me explain. I'm trying to add an opacity map to a texture, but somewhy as soon as I add the opacity map the respective area messes up: Areas that aren't supposed to be transparent get so, even with the opacity slider at 100% and the majority of the map white.
I tried to use the opacity map as a texture, to see if it's black and white where it's supposed to be transparent and opaque, and it's alright.
It seems the slider in itself it's working strangely too: if I put it at around 98%, a big part of the texture suddenly gets transparent
Any help would be awesome,
Cheers. ;-)
  • fixmypcmikefixmypcmike Posts: 19,612
    OpenGL (which is what is used for the viewport) has problems displaying multiple opacity maps. Does it look correct when you render using 3delight (software render)?
  • oocreepyoocreepy Posts: 0
    edited October 2012
    Yeah, it does! Good thing it was so easy :-D
    Thank you for the help. :-)
    Post edited by oocreepy on
