Troublesome Render Settings
BrotherloboBrotherlobo Posts: 495
Recently...my viewport keeps changing from 'Active Viewport' to 'Custom' in my Render Settings. It seems everytime I load something new, it switches back to 'Custom' -- I have looked through the settings and cannot figure out the command to stop this. Its not a major problem, just annoying. Any advice?
    There was a bug in an earlier version which was fixed. I think that happened in 4.5.0.114 is that what you are running?
  • JaderailJaderail Posts: 0
    Yes, it is a Bug in 114, it will stop for a time (then start again with some install) if you set it the way you want and then save a Layout Setting.
  • BrotherloboBrotherlobo Posts: 495
    Yes, that is the version I'm running. I take it that there hasn't been a patch/fix for it yet?
    As I said, its just annoying!
  • fixmypcmikefixmypcmike Posts: 19,612
    It's fixed in 4.5.1.6, I believe.
    It was actually fixed in 4.5.0.137, but it is still fixed in 4.5.1.6 :)
