Selection in Surface Pane using script
![Edpa](https://secure.gravatar.com/avatar/c4062770440bd5ea0609fbe6fafe445e?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2Fc4062770440bd5ea0609fbe6fafe445e_100.png)
I know how to select node by label (findNodeByLabel( "..." )).
But how to make this in Surface Pane - to example choose "Opacity" or other item here? Thanks
You would do better to go to the item directly rather than through the pane. This script sample shows how to get a material from an object and access its properties http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/properties/material_properties/start
Ok! It's working correctly. Changes a little and OK. Thank you very much.
Modified place from this script :)
