Problem With Maps and Applying Shaders
tonykidd237_12ede28951
I'm having some issues with applying shaders. Skin materials go on just fine. However, when I've used the surface selection tool to select the figure's surfaces and apply a shader it simply replaces the map information without the option window asking me to replace or ignore.
Anyone know what I'm doing wrong here?
Hold down the control key when applying the shader.
Also make sure you have the object AND the Surface selected, just adding that for completeness.
Thanks. Worked like a charm! The only thing I wasn't doing was holding down ctrl.
