bullet physics for DS 1, 2, 3, 4 PC/Win ... teaser
mCasualmCasual Posts: 4,607
edited October 2013 in Freebies
it will probably work like this
you place primitive objects ( spheres cubes cylinders ) in a Daz Studio Scene
there will be a "mass" parameter added to each object ... using a script
if the mass of the object is 0 it will be considered static ( ground/floor objects for example )
then the script will outsource the physics simulation job to an executable/program ( PC-Win only )
a few seconds later the script will apply the physics simulation results to the objects in the scene by keyframing/animating them
here is the output of my Bullet physics server for the Y position of a sphere falling on the ground ... apparently there's no bounciness ... for now
884 x 426 - 38K
Post edited by mCasual on
«13456711
  • DorseylandDorseyland Posts: 724
    You lost me at "Bullet", and I don't mean politically. It's an animation script for what???
    If this is what you do when you're Casual, what do you come up with when you're Intense?
  • mCasualmCasual Posts: 4,607
    edited October 2013
    example : in a daz scene, you place a soccer ball 4 ft above ground
    you let the script/program figure what should happen next
    and the ball falls to the ground and possibly bounces
    in the image below the Jupiter2 ship makes a hard landing
    there used to be a plugin for Daz Studio 3 to do this http://www.youtube.com/watch?v=jTTekEgxzJk
    my script+program will probably be less practical than this but for simple effects it should do the trick
    600 x 337 - 240K
    1920 x 1080 - 381K
    480 x 270 - 723K
    edited October 2013
    3 objects !
    next time i'll take rotations into consideration, so the cubes should tumble
    figure 2 -- well the rotations are inverted because DS's Z axis in the opposite of the Physics engine but it tumbles !!
    480 x 480 - 427K
    600 x 337 - 211K
    edited October 2013
    tada ! i inverted the quaternion's Z component and it did the trick :)
    ( there's still an inverted rotation axis dang it )
    800 x 600 - 875K
    480 x 480 - 428K
  • MattymanxMattymanx Posts: 6,953
    while I dont do animation this will still be a good way to get a dispertion of objects for scenes where destruction or a mess is required.
  • WandWWandW Posts: 2,846
    I
    Bullet Physics is the physics simulation system that's used in Cararra and Poser...
    for more credible wrecking , pre-fractured cinder blocks would be needed
    more complicated effects like that would be done in Blender,
    but my script+exe kit should be okay for heaping unbroken stuff
    1280 x 720 - 220K
  • ghastlycomicghastlycomic Posts: 2,531
    Is there a thread that explains what scripts are and how they are used? All this script stuff posted here looks very interesting but I don't know what exactly it is or how easy it is to use. Does it require a lot of programming to use it? The last programming I did was in 6507 machine code for the Atari 2600.
    edited October 2013
    you don't need to program to use the scripts
    a daz script is like a program that runs inside daz studio
    the daz scripts files have names like dothis.dsa and dothis.dsb
    the .dsa scripts can be edited using a text editor or the Daz Studio Scripting IDE
    the scripting language is extremely similar to javascript
    on my site there's dozens of scripts
    if we take a simple one https://sites.google.com/site/mcasualsdazscripts2/mcjlookatthecamera
    i distribute it as a zip file
    if you unzip this in a daz studio content folder, you'll be able to activate/run the script using Daz Studio's content tab
    for example, if i download and unzip mcjlookatthecamera.zip in
    C:\Users\MYUSERNAME\Documents\DAZ 3D\Studio\My Library
    i will find the script in the content tab under
    Daz Studio Formats / My Library / Scripts / mcasual
    ( see image attached )
    now according to the instructions, i select Aiko's head
    then in the content folder i double-left-click on the mcjlookatthecamera thumbdail/icon
    and the script will turn Aiko's face toward the camera ( your point of view )
    812 x 492 - 49K
    edited October 2013
    hammertime soon? we wont make promises :)
    1280 x 720 - 215K
    1280 x 720 - 158K
  • Richard HaseltineRichard Haseltine Posts: 102,625
    .dsa (or .dsb) presets for materials and so on are scripts, too.
    edited October 2013
    here you see a Daz Studio scene with 3 physics objects
    the ground-cube is a "static" body
    one cube is a "kinetic" body which i animated, it can influence dynamic objects but is not influenced by them
    and one cube is a "dynamic" body, it gets pushed off the flat planet
    note that this whole physics kit will not have all the functionalities available in Blender's port of Bullet Physics
    so, down the road, i may write a script that helps you send a Daz studio scene over to Blender for physics simulations
    480 x 270 - 535K
  • bighbigh Posts: 8,147
    you going to have rag doll ?
    edited October 2013
    i plan to include bullet-physic's 5 types of constraints
    one of them is said to be suited for ragdolls
    this would probably make it possible to build a doll out of cylinders then throw it around
    connecting this doll to a figure like Aiko or Genesis ... will come later
    according to the documentation there's also a vehicle/car rig
    note that i don't want to go too far in this project because i have a lot of script updates on the back-burner
    so, the moment i get the constraints working, i'll post this script+ program , and jump back to unfinished projects
    reminder : this is a PC-Win system
    but but but someday i may write a Mac compatible system that brings Blender3D's physics simulation services to Daz Studio
    900 x 900 - 105K
  • Takeo.KenseiTakeo.Kensei Posts: 1,303
    Very cool Casual. I was planning to play with Bullet Physic to see what I can get out of it but didn't do anything yet
    possibly fixed the inverted rotations issue
    480 x 270 - 479K
    in the meantime you can do all this and more in Blender3d
    when my script will be ready , it will have the advantage that it's easier to build a scene and animate it in Daz Studio, and the renders can be fast
    and maybe maybe i'll add softbodies/cloth physics later
    though with constraints and solid bodies we can do ropes and chains ... maybe some pseudo-dynamic hair/tresses too
    https://www.youtube.com/watch?v=U93qc4ZJYEk
    edited October 2013
    Fig. 2 the test scene for further work on rotations
    so far the daz scene objects were not rotated at all before being sent to the physics engine
    Fig. 1 - typical data file passed to the physics engine server ( mcjBulletServer001.exe ) by the daz script mcjBulletClient.dsa
    886 x 384 - 22K
    1280 x 720 - 379K
    I know I can do that and more in blender. That would just be for the fun of coding. I'm rather coding RSL shaders but I lastly setup eclipse for python coding inside blender to update some plugins that were broken because of blender update; I just thought that I could also set it up for something else.
    edited October 2013
    Amy decided to stay on the sidelines ( or sidewalls) for this one because she's not suicidal )
    ( my script can now pass rotated bodies to the physics engine )
    well the rotation issue is not really correct, the springnoard ....the way it falls through the edge of the ground-cube
    to do to do to do ... sunday :)
    oh and while we're at it, see in fig 2 the test i did before the one of fig 1.
    there's very very fluffy mattresses not shown nobody was injured
    600 x 450 - 199K
    480 x 360 - 805K
    Clever! :-)
    Clever! :-)
    thanks ! ( i still have to do more test to make sure i was clever enough: )
    shown here - same test scene with greater precision
    since this is not happening in real-time we can wait the 1 or 2 second it takes
    400 x 300 - 446K
    Amy's finger tip is a "kinetic" body, the sledgehammer is a dynamic body and the floor-cube is a static body
    400 x 225 - 457K
    Technically, could one then turn the dynamic body to a kinetic one, to in turn move a third item ... a domino effect?
    edited October 2013
    you can make all the dominos "dynamic"
    and they'll fall like dominos :)
    the animated/kinetic object ( Amy's finger ) can push the first domino
    in my next text i'll throw the ball in the blocks-wall and blocks as you'll will react to one-another
    480 x 270 - 687K
    This is really fascinating.
    edited October 2013
    first wall bustin' simulation
    i have to read more about ways to prevent the blocks from sinking in the ground
    awwwh i think i know ... it's because i did not yet fix the rotations issue
    quaternions have to be handled with care i cant just wing it :)
    480 x 270 - 576K
    I love that the one block sees the ball coming and says "Screw this, I'm out of here".
    Yeah! lol ...
    now correctly computing the dimensions of rotated objects
    and ... a first simulation involving a sphere
    pretty neat simulation results
    480 x 360 - 851K
