G8F/M Pose Transfer to G9
![richardandtracy](https://delorean.daz3d.com/forums/uploads/userpics/010/nULALLFIM72BT.jpg)
I saw yesterday that a number of people were suffering from a small number of G9 poses being available. So, can I offer a 4575 line script to transfer poses to G9. You need to have the pose applied to G8F, and it is then transferred to G9 by the script. You need to select the hip of each appropriate character. The script makes a guess as to which is which in the scene, but you need to confirm or correct the choices.
G8F and G9 are very similar, so the poses convert pretty well. The biggest problem preventing immediate use of G8 poses is that the bone names are quite different, and a few bones have different zero settings. I used about 1700 lines of code to get the face rig to transfer, something I've not done in any previous transfer script. This is one area where not everything has a 1:1 equivalence, so I have tried to make it work as well as possible - if anything G8F has more bones in the face than G9. In the lips & eyelids I've had to average up to 3 G8F bone dial values to go into one G9 parameter dial. Not everyone wants the face rig pose to come over with the body pose, so the face rig pose transfer is optional with a checkbox. The head, ears and eye poses always transfer with the body pose.
I do hope it's useful until someone like RiversoftArt can come up with a pose transfer that doesn't need G8F to be open.
Pose shown: BBarbs freebie 'Just Elegant 07' from Renderosity, Characters CHB Milan and V9. Background is Namtar3D's underwater HDRI available somewhere on this forum and at Renderosity.
The image shows that the pose has transferred properly, but due to different limb lengths between the characters, V9's right fingers are embedded in her heel. This is something that you would have had to deal with between two G8 characters and is not something the script can cope with. Allen Art reports below that it works with male figures. I've not tested it but can't see any reason why it wouldn't.
Regards
Richard
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/4b/74fb0a16970aafd027e54151429b2e.png)
![](/forums/plugins/FileUpload/images/file.png)
Thanks for this, I just converted a pose by copy pasting each bone, it worked ok-ish except for upper arm and leg rotations, but still needed a lot of tweaking.
This will be a real time saver.
Thank you so much!
Thank you. Now to just do ALL my library *nervous laughter.*
Thank you.
Thank you so much! I'll be giving this a try later tonight :)
Thank you very much Richard, I will give this a try soon!
thanks! This will be really useful...
Thank you. They do work on the male :)
Many Many Thanks. Cheers
Thank you Richard :-)
One of Shimuzu's :) Thanks again!
Very cool render AllenArt!
I have transferred a fairy pose over from Genesis 8f and have a render cooking at the moment. I'll try and remember to post here.
This is awesome, Richard!![smiley smiley](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/regular_smile.png)
![yes yes](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/thumbs_up.png)
Thanks to your script Richard and some tweaking of mine, Yves G9 is sitting in a G8M base pose!
Looking good imo!
Kudos!
AOBB
Many thanks!! Tried a few poses and everything was OK!
Fairy render as promised using a converted genesis8f fairy pose. Uses gu from Zev and my face morphs.
thanks![heart heart](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/heart.png)
I had to do 38 "poses" but yay now I have a walk cycle
turning it back into an aniblock is unfortunately beyond my skill set, I never have been able to create aniblocks that connect to each other
(it was the G8F flatfooted walk cycle aniblock baked to timeline in place)
video
yeah not many animation options for Genesis 3 onwards in DAZ anyway unless premade
like Gofigure's AniBlocks
can sort of use ones imported on Genesis 1 with footslide issues on 3 and 8
or unless you own MotionBuilder as the BVH import is terrible
this figure nothing worked
I am guessing GoFigue, Bonetech, Reisermocap etc all use MoBu
Thank you very much for this nice freebie!
Great! Thanks ;-)
Great, now we all hope that someone create a script tu use G8 morphs on G9 :)
Thanks Richard
thank you!!
someone was taking the wrong lesson from apple and made a new phone that doesn't fit the old charger... I mean even a limited way of applying the old gen poses would have been welcome, like limited to body/legs/arms, then you can fiddle with expression, hands, neck etc like people usually do anyway, but having nothing at all is just - disappointing, very
